Hi There,
I have installed nagios 3.4.1 on CentOS 6.3 from source. Everything looks great except I am missing check_snmp plug-in or I need to install it.
1. Where can I download this plugin?
2. How do I install the plugin?
Thank you very much for all your help!
Missing check_snmp plug-in
lcontreras
Re: Missing check_snmp plug-in
Hi Junglecon,
This happened because, before installing Nagios 3.x you needed to have some snmp packages installed like net-snmp net-snmp-libs net-snmp-devel net-snmp-utils net-snmp-perl
Attached to this reply the check_snmp file, copy it to /usr/local/nagios/libexec and assign it the permissions.
regards
Luis
regards
Luis
- check_smtp.rar
- check_snmp
- (46.66 KiB) Downloaded 421 times
Thanks for your reply but i figured it out yesterday night finally.
I did not have the yum net-snmp packages installed when I installed the plugins
I just ran:
1. yum install net-snmp*
2. ./configure --with-nagios-user=nagios --with-nagios-group=nagios
3. make && make install
The check_snmp is now where it should be.
Thanks again for your help!
I just ran:
