Help in deleting some stuff in /var
srikanth.kallu
Post by srikanth.kallu »
Can i get help in deleting some stuff in /var.
I am not sure what should i delete in there, Afraid if i delete something important
Thank You.
mguthrie
Re: Help in deleting some stuff in /var
Post by mguthrie »
Most things in /var ARE important. I'm assuming you're running out of hard disk space?
Is this a physical machine or a VM?
srikanth.kallu
It's VM
mguthrie
Post by mguthrie »
If you're running out of space, you're better off resizing the partition using the doc below to give the machine more hard disk space. If you have to clear space in /var to keep the system running, it's not giving the system much breathing room, and you might clear it once, but it's likely that it would fill up again.
http://assets.nagios.com/downloads/nagi ... M_Disk.pdf
srikanth.kallu
That is good document to know hos to increase space,
I am in a stiuation that i cannot increase the space and defenetly delete something,
What is the best solution in this.
mguthrie
Post by mguthrie »
First things first, delete at your own risk. If you need data from any of these files, do not delete them.
Current Logs:
/var/log/httpd/access_*
/var/log/httpd/error_*
Old Logs:
rm -f /var/log/secure.*
rm -f /var/log/messages.*
rm -f /var/log/cron.*
Mail Files
/var/spool/mail/root (this assumes don't use the root mail account on this system)
/var/spool/mail/nagios
