Network Status Maps -Dependencies not displayed
fkroeger
Post by fkroeger »
I have setup several hosts and set the dependencies via the Core Config Manager. The hostdependencies.cfg appears to update OK - (attached below).
However, when I select the Network Status Map, the dependencies are not displayed. They are all shown as coming from the root of Nagios.
Is there something else I need to do to display these Parent/Child relationships?
regards... Fred
define hostdependency {
       dependent_host_name               hostb
       host_name                                hosta
       inherits_parent                          1
       dependent_host_name               hostc
       host_name                                hostb
       inherits_parent                          1
       dependent_host_name               hostd
       host_name                                hostc
       inherits_parent                          1
admin
Site Admin
Re: Network Status Maps -Dependencies not displayed
Post by admin »
Hi Fred -
Dependencies aren't what you're looking for to accomplish this. What you need to do is this...
When you're editing a host in the Nagios Core Config Manager (NagiosQL), specify the parent host in the "Parents" field. The parent relationship is what determines how hosts are "connected" to each other, and this will be reflected in the network status map when you apply the configuration.
Ethan Galstad
President
fkroeger
Post by fkroeger »
Resolved - thanks - that fixed the dependancy issue.
I saw the Host Dependency tab in the Advanced section of Core Config Manager and thought this was a great way to setup all the dependecies : ie: if I setup a hostgroup as being dependent on a particular host, then I thought that just by adding another host to that hostgroup would setup the dependency - maybe I was tryign to be too clever!
So what do I achieve then by using this Host or Service dependency in the advanced section?
Regards... Fred
