NSCA Limitiation
blariv
NSCA Limitiation
Post by blariv »
wondering if there was a limit of passive checks that can be sent from nsclient to XI. I currently have about 15 checks and only 11 show up in unconfigured objects.
Re: NSCA Limitiation
Is the host already configured with service descriptions for the other 4.
For example, if you added 4, they show up in unconfigured objects. If you add them, they will not be unconfigured any longer.
Then you add more check in nsclient++, the new items will show in unconfigured but not the old items.
If this isn't the case, I would look at the nsclient.log to see if there was an error executing the check
blariv
Post by blariv »
jumped the gun as usual.
I reinstalled nsclient and everything is working correctly.
thanks for the quick reply as usual.
