127 Return code out of bounds-plugin may be missing
listening723
Post by listening723 »
127 Return code out of bounds-plugin may be missing . what does this actually mean do I need to install the default pulgins for nagios again or need to make any configuration changes. Am attaching the jpg file please go through it and help me out with a solution.
Thank you
sreinhardt
-fno-stack-protector
Re: 127 Return code out of bounds-plugin may be missing
Post by sreinhardt »
Most likely yes you will need to recompile and install, but be sure that net-snmp is installed from yum first. Most often the issue is that it was not compiled with other plugins due to that packaged missing.
listening723
I have reinstalled the plugins and compiled it but not change still showing me the alert 127 return code out of bounds- plugin may be missing
sreinhardt
Just to verify, did you run a "yum install net-snmp" before recompiling?
