Availability Report error
wiproltdwiv
Post by wiproltdwiv »
hi,
we are not able to generate availability report in pdf. we are using nagios xi 2012 R1.2
please find the output for your ref
[root@EMSNagios1 etc]# cat /etc/php.ini | grep display_errors
; display_errors
display_errors = On
; separately from display_errors. PHP's default behavior is to suppress those
[root@EMSNagios1 etc]# cat /etc/hosts
127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4
::1 localhost localhost.localdomain localhost6 localhost6.localdomain6
10.128.17.13 EMSNagios2
10.128.17.14 punbkpsrv
10.128.17.12 EMSNagios1.co-opbank.co.in
172.29.70.42 EMSNagios1.co-opbank.co.in
wiproltdwiv
Re: Availability Report error
Except availability and notification , we can able to generate other reports in pdf
Can you print reports in pdf if when you change this line in the "/etc/php.ini"
display_errors = On
to
display_errors = Off
and restart apache?
service httpd restart
What does it show on the screen when click on the "Download as pdf" icon? Error messages, blank screen...?
wiproltdwiv
It showing attached error.
display_errors = On
to
and restart apache?
