hello,
I installed NagiosXI on lan 192.168.40.x (Server's Lan)
I get an error from the PC network (192.9.201.x)
403 - Forbidden: Access is denied.
You do not have permission to view this directory or page using the credentials that you supplied.
where can I allow the network 192.9.201.x?
Thanks.
J-Fr.
Re: 403 - Forbidden: Access is denied.
Can you access the server's LAN from the 192.9.201.x? Proxies, firewall? It's seems to be a network issue.
Routing works very well between lan. No firewall, routing only.
nagiosxi responds 403 - Forbidden: Access is denied. when I try access http://192.168.40.200/nagiosxi from my host 192.9.201.169
I think a problem htaccess or cgi.cfg
I found the problem. Another machine (not respond to ping) had the same ip that server nagios.
Thank you for your help.
I'm glad this is resolved!
