Error: Service check command 'check_http -H ...'
happy
Post by happy »
Hi
I am trying to monitor website performance through Nagios by doing the following:
in windows.cfg file I have the host already defined (the same host is checking for disk space, etc)
In the same file I have added a service to monitor a website
        use                    generic-service
        host_name              myhostname
        service_description    HTTP
        check_command          check_http -H myurl
I have this defined in the command.cfg
# 'check_http' command definition
        command_name    check_http
        command_line    $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
When I run verification I get this error:
Error: Service check command 'check_http -H myurl' specified in service 'HTTP' for host 'myhostname' not defined anywhere!
Additional Info: I am able to run this command check_http -H myurl from the terminal session and get a response.
I feel that I might have missed defining definition some place and wonder if anyone knows about the missing puzzle ....
Thanks!
jsmurphy
Re: Error: Service check command 'check_http -H ...'
Post by jsmurphy »
I think you accidentally the exclamation ;) .
        use                    generic-service
        check_command          check_http!-H myurl
happy
Post by happy »
Great job! I had simply copy pasted it from an online post and missed adding an exclamation :)
Many Thanks for taking time to respond!
Post by slansing »
Thanks Jsmurphy! And glad to hear this fixed your issue, thank's for the feedback.
