Linux Distribution and version?
1. Cent OS 6.2 / 64 Bit
2. Manual Install
3. Gnome installed
To Nagios XI Tech Support Specialist:
I am still getting this error. What would you suggest I do to fix this?
DB Connect Error [nagiosxi]: Database connection failed SQL: SQL Error [nagiosxi] : Database connection failed SQL: SQL Error [nagiosxi] : Database connection failed DB Connect Error [nagiosxi]: Database connection failed DB Connect Error [nagiosxi]: Database connection failed
Re: DB Connect Error [nagiosxi]: Database connection failed
The main Nagios office is closed today and tomorrow for the holiday, so you're not likely to hear anything until Wednesday from them.
Did you try restarting mysql?
Tried rebooted the machine completely?
Looked through var/log/messages?
Edit: I didn't see this was a duplicate post...
Judging from the output in the other thread, you have a postgre problem. You need to run the commands they told you to in the other thread.
service mysqld restartLooked through var/log/messages?
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
locking as this is a duplicate problem.
