I have 3 monitoring servers that submit passive checks to a main reporting server. Under tactical overview however, I have ~7000 active host/service checks and only ~1000 passive host/service checks. I am running nagios 3.4.1 and nsca 2.9 with OCSP.
How do I correct the behavior of passive checks going back to ~7000 or so, is there a setting that throttles the amount of passive checks being passed? I noticed the passive checks weren't passing as much when I upgraded nsca 2.7 to 2.9.
Any help would be greatly appreciated.
Passive checks issue
Re: Passive checks issue
There is an issue with the current nsca release in regards to nsclient (and maybe others). See the following forum post as it has a link to the nsca downgrade:
http://support.nagios.com/forum/viewtop ... sca#p34364
Additionally, make sure both the client and server binaries are the same version. You can check by running the following on both boxes:
root@localhost$ cd /usr/local/nagios/bin
root@localhost$ ./nsca -V
