I have begun using the Nagios XI Enterprise 2012R1.3 VMware VM from the downloads site while I am waiting on my license key to be sent over.
So far, so good with one exception...
Under "Reports -> Bandwidth Usage", I am getting the updated graphs as I do everywhere else, however the statistics are not being updated.
I have been grepping for the past hour looking for what script would update these numbers, however as of yet I have not been able to track it down.
For what it is worth, the usage speeds do report correctly under the individual interface Bandwidth checks, it just seems that wherever the throughput numbers get stored, calculated or displayed is not behaving as one would expect.
For these interfaces, I am using the standard check_xi_service_mrtgtraf command and the xiwizard_switch_port_bandwidth_service template.
All aspects of this check have been implemented via the Network Switch / Router Monitoring Wizard.
Could anyone point me in the right direction to get this report to a working state?
Bandwidth Usage Reports Not Updating
tysonedwards
Re: Bandwidth Usage Reports Not Updating
Just saw your post had slipped through the cracks... Did the data start coming in?
If not do you have data before you drill into the specific month?
