Monitor JMX attributes using check_jmx plugin
remyapoulose
I am monitoring JMX attributes with nagios plugin check_jmx with the help of NRPE. This plugin spawns mutiple processes named JMXQuery and the system hangs after that. What is the reason for that and how this plugin works?
Re: Monitor JMX attributes using check_jmx plugin
I'm not familiar that plugin, you may get a better response from the developer on their sourceforge page
http://sourceforge.net/projects/nagioscheckjmx/
