I've setup nagiosxi and I cannot connect to the core config manager. I receive the following error "Cannot connect to database"
mysql is running
I can connect to the database with the credentials in the following file /var/www/html/nagiosql/config/settings.php using mysql -u username -p'password' nagiosql
Cannot Connect to Core Config Manager
Re: Cannot Connect to Core Config Manager
Try the following solution from our Wiki and see if it resolves your issue:
http://support.nagios.com/wiki/index.ph ... ig_Manager
Thanks working fine now.
