1. I have installed trial version of nagios xi and configure hosts but then i have realized i haven't set agent's password.
Configuring agent's password only available during initial setup so i deleted all the hosts and tried to reinstall them all.
However, host detail still showed all the hosts and service details showed after i reconfigure hosts.
In CCM, i could delete services and hosts but it still shows on the host details.
Is there a way to remove them all and start over?
2. I had to reboot nagio server from VM Ware to upgrade memory and when i reopen UI, all the service details disappear.
I tried to restart agents and add hosts again but nothing shows.
Could you please help on these matters?
Thank you
service details not available
Re: service details not available
Can you apply configuration successfully? Try to verify the nagiosXI config files:
Config --> Core Config Manager --> Tools --> Write Config Files --> Click Write --> Then Click Verify
Do you receive any errors?
I didn't receive any errors.
Post a listing of the XI config files directory:
Make sure that the listed hosts and services are ones currently setup in XI.
Also, try to "write config files" and "apply configuration" in XI to make sure your config files changes were written out.
ls /usr/local/nagios/etc/hosts
ls /usr/local/nagios/etc/servicesAlso, try to "write config files" and "apply configuration" in XI to make sure your config files changes were written out.
Error: Invalid max_check_attempts value for host 'redcac10.mwfinc.com'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/redcac10.mwfinc.com.cfg', starting on line 14)
Nagios Core 3.4.1
Last Modified: 05-11-2012
License: GPL
Nagios Core 3.4.1
License: GPL
This got me the first time I setup a check in XI as well. You need to define the following to create a valid check:
On the "Check settings" tab:
Check interval
Retry interval
Max check attempts
Check Period
and
On the "Alert Settings" tab:
Notification period
Check interval
Retry interval
Max check attempts
Check Period
and
Notification period
i could not see where to find "check setting" tab.
please help.
please help.
The Check Settings tab is located under the service's edit page within the Core Config Manager.
Go to:
Configure (on the top blue bar) --> Core Config Manager (left hand pane) --> (log in) --> Hosts (left hand pane) --> Click the problematic host (redcac10.mwfinc.com) --> You should see "Host Management" in the right hand pane --> click the "Check Settings" tab --> Set the "Max Check Attempts" value --> Click "save" and then "Apply Configuration"
Thank you so much. I finally found it!
What's the difference between xi_timeperiod_24x7 and 24x7?
I guess the service detail doesn't show anymore because i reset the nagios server?
Is there a way to wipe out and start over?
