BPI service check issue
westernuniv
Post by westernuniv »
Hi
I’m using nagios BPI 2.2 and I can create new groups and display in XI without any issue. I’ve installed BPI Wizard 1.1 to create service checks for my bpi groups, when I crate a BPI service using the wizard, I’m getting “Unknown BPI Group Index” error for all the groups
Eg:
# /usr/local/nagios/libexec/check_bpi.php mail
#!/usr/bin/php
mguthrie
Re: BPI service check issue
Post by mguthrie »
This is a known issue that showed up in the last release. I'll try and get an updated version of the component posted to this thread later today that should resolve the issue.
mguthrie
Post by mguthrie »
Here's the latest version of the BPI component. This component will also be automatically updated with the 2012r1.4 release which should be posted early next week.
