How to print out Nagios Service UP Time Percentage?
kunus
Post by kunus »
How to print out Nagios Service UP Time Percentage from Nagios-Report Perl Module?
I can print out Host UP Time percentage from Nagios-Report Perl Module with following code:
#!/usr/bin/perl
use strict ;
use Nagios::Report ;
my $x = Nagios::Report->new(q<local_cgi localhost nagiosadmin>)
  or die "Can't construct Nagios::Report object." ;
$x->mkreport(
                [ qw(HOST_NAME PERCENT_TOTAL_TIME_UP) ],
                sub {
                        my %F = @_; my $u = $F{PERCENT_TOTAL_TIME_UP}; $u =~ s/%//;
                        0,
                sub {
                        my $F = shift @_ ;
$x->debug_dump ;
But How can I only print out Service UP Time Percentage? I mean only output the percentage value.
I tried many options but couldn't get it right.
Edit: This will produce Service UP Time Report, but How can I only retrieve UP Time percentage value instead of full report?
  #!/usr/bin/perl
    use strict ;
                         # Data source
                q<local_cgi localhost nagiosadmin>,
                         # Report period
                [ qw(24x7) ],
                         # Time period
                'last7days',
                         # Service report
                1,
                         # Pre-filter
                sub { my %F = @_; my $u = $F{PERCENT_TOTAL_TIME_OK}; $u =~ s/%//; $u < 100 }
    $x->mkreport(
          qw(
              HOST_NAME
              DOWN
              UP
              OUTAGE
          sub { my %F = @_; my $u = $F{PERCENT_TOTAL_TIME_OK}; $u =~ s/%//; $u < 100 },
          undef,
          undef,
          1,
    $x->debug_dump() ;
Edit 2: Any Ideas? or any other way to retrieve UP Time percentage? e.g. PHP Class, Command Line Tools or ..
Re: How to print out Nagios Service UP Time Percentage?
Post by slansing »
So I guess I don't understand, are you attempting to add a Service's up time to another report? Because the first question you asked does not match the second one it looks like you want to create a separate service report, are you confusing this with check results? Lets just clear that up first.
kunus
Post by kunus »
Hi again and Thank you. Yes I'm trying to generate another service report. and I'm looking for someway to retrieve a service uptime. any ideas?
abrist
Red Shirt
Post by abrist »
In the availability reporting component, if you specify a host, you will get percentages for all the service for the given time period.
