Could you please consider adding support for "Unknown" status state to the operations screen? I was able to modify the opscreen.php and merlin.php to change row color to orange if the state=3 (unknown) however it would be great to see this added to the next release. I've attached the two files for reference.
Ryan
Operations Screen Improvement
ryan_breneman
Re: Operations Screen Improvement
Sure, you can add this as a feature request by opening a bug report and selecting "Feature Request" from the dropdown at:
http://tracker.nagios.com/
This ensures that all of our developers can take a look at the request.
ryan_breneman
Great, thanks! I just submitted it.
Great, thanks for letting us know. Locking this thread.
