Help in understanding SWAP usage graph
srikanth.kallu
Post by srikanth.kallu »
Why would the graph for swap utilization go down to 0 when this is copmpletly utilized, we normally expect the graph to go up when the utilzation is high right.
Re: Help in understanding SWAP usage graph
Post by slansing »
What plugin are you using to check this? It is possible that it is showing you the amount of space left to be allocated and not the percent used.
