Schedule report?!
xpertech
Schedule report?!
Post by xpertech »
1. There is "schedule" feature on most of the reports, but "Bandwidth Usage Report" doesn't have this feature?
2. The "Bandwidth Usage Report" is based on selected "port", is there possible to select by "port group" or "device"?
3. On service detail performance graphs, Is there possible to schedule report?
4. Can I export "reports" to "PDF" files?
abrist
Red Shirt
Re: Schedule report?!
Post by abrist »
xpertech wrote:1. There is "schedule" feature on most of the reports, but "Bandwidth Usage Report" doesn't have this feature?
Bandwidth reports do not have a schedule option currently. You can open a feature request @ tracker.nagios.com though.
This would be a bandwidth aggregation report. We do not currently have one, but this feature has been requested often enough that I think it is being worked on. I will get back to you on this one.
Not possible currently. Again, you may want to include this in a feature request.
Some you can. You will find a pdf icon in the upper right corner of the report if it is available. You can also print many of the graphs in reports and graph explorer. You could always install a pdf printer and print to a pdf.
