Hi there,
I am new to Nagios XI. I was trying to install xi-2011r1.9 on a clean CentOS 6. However, after I run ./fullinstall. I got following errors:
What I can do to fix it? Thanks.
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /tmp/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: cannot access /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
ERROR: NagiosQL import appears to have failed - exiting. (Reason: Import files are still present in /usr/local/nagios/etc/import)
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './E-importnagiosql'
Failed to install xi-2011r1.9
sreinhardt
- -fno-stack-protector
Re: Failed to install xi-2011r1.9
It would appear that the nagios install believes that you are attempting an upgrade of an existing installation. Most likely this is due to running ./fullinstall mutliple times. Could you attach your install.log file please?
In addition to sreinhardt's reply, since you are new to Nagios XI is there a reason you are planning to work with 2011 r1.9? The current version is 2012 r1.3 and between the two versions there are a whole host of additions and fixes.
Yes, I am testing an issue on 2011r1.9.slansing wrote:In addition to sreinhardt's reply, since you are new to Nagios XI is there a reason you are planning to work with 2011 r1.9? The current version is 2012 r1.3 and between the two versions there are a whole host of additions and fixes.
Here is the install.log file.sreinhardt wrote:It would appear that the nagios install believes that you are attempting an upgrade of an existing installation. Most likely this is due to running ./fullinstall mutliple times. Could you attach your install.log file please?
I never tried to run fullinstall before. The VM is a clean installed CentOS 6.
We cannot guarantee that the fullinstall will work on a release from a year ago as there may be dependencies that have been moved...
I can post a link to a 2011r1.9 vmware image if you like.
This will work about 30 minutes after I post this as I am uploading it now.
http://assets.nagios.com/downloads/nagi ... vmware.zip
Thanks, Let me try on it.
Sounds good, let us know how it works for you.
