Restore script errors
BenCowan
Post by BenCowan »
At some point the Backup and Restore scripts changed from using zip/unzip to gzip/tar, and ever
since I get the following errors:
tar: nagiosxi_backup/nagios.tar.gz: Not found in archive
tar: Error exit delayed from previous errors
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: usr/local/nagios/bin/nagios: Not found in archive
WARNING: you are trying to restore a backup on a 64-bit system
Plugins and other binaries will NOT be restored.
Can NagiosXI also include the option to use the old method of backup and restore?
Re: Restore script errors
Post by slansing »
What version of Nagios XI are you currently running, and what version was the backup you are trying to restore made from?
BenCowan
Post by BenCowan »
Both the backup and restore were Nagios XI 2012R1.3
The restore script expects that the file hasn't been renamed
If you look in the tarball you will see that the inside it is named with a timestamp
If you rename your nagios.tar.gz file to the appropriate {timestamp}.tar.gz it should work fine.
BenCowan
Post by BenCowan »
Thanks, that was it.
jbennett
Post by jbennett »
I have run into this same issue on 1.4.
I have extracted the nagios.tar.gz file from my backup, but I'm not seeing a time stamped file within that tar ball?
Actually, the backup script will make a file like 1348511708.tar.gz
If you rename this file to nagiosxi.tar.gz, in order to find out what you need to rename it back to you would need to run
gunzip nagiosxi.tar.gz
then
ls -l
total 202776
-rw-r--r-- 1 root root 95129600 Sep 24 13:35 1348511708.tar
-rw-r--r-- 1 root root 61867430 Nov 28 12:46 nagiosxi.tar.gz
Yo will see you now have 1348511708.tar
1348511708.tar.gz is what you would need to rename the file to.
jbennett
Post by jbennett »
# mv 1358874071.tar.gz nagiosxi.tar.gz
# gunzip nagiosxi.tar.gz
# ls -l
total 1527672
-rw-r--r-- 1 root root 1535805440 Jan 22 12:00 nagiosxi.tar
Unfortunately, I don't get that same result.
Looking at your example, the time stamp is the same as the original file name, couldn't I just rename nagiosxi.tar as 1358874071.tar then gzip it again?
likely yes
jbennett
Post by jbennett »
So, I'm just renaming the original file to the original name? Apparently, somewhere along the way, I've gotten lost...
# mv nagiosxi.tar 1358874071.tar
# gzip 1358874071.tar
# ls -lh
total 1.1G
-rw-r--r-- 1 root root 1.1G Jan 22 12:00 1358874071.tar.gz
# /usr/local/nagiosxi/scripts/restore_xi.sh /store/backups/nagiosxi/1358874071.tar.gz
tar: 1358874071/nagios.tar.gz: Not found in archive
Are you sure you want to continue? [y/N]
I should note that within the 1358874081.tar.gz file, I do have nagios.tar.gz already.
