[clarkj@svphlnagios02 nagiosxi]$ sudo ./upgrade
OLD VERSION: 303
ERROR 1060 (42S21) at line 1: Duplicate column name 'locale'
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
It would seem that you are seeing a mysql error on line 371 if ./upgrade. Can you check if you currently have a locale column in the tbl_user table? If so, or if you have already ran the upgrade script once and it error-ed out, you may try commenting this line out.
sreinhardt wrote:It would seem that you are seeing a mysql error on line 371 if ./upgrade. Can you check if you currently have a locale column in the tbl_user table? If so, or if you have already ran the upgrade script once and it error-ed out, you may try commenting this line out.
Yes, there already is a locale field in that table. Any clue why it would be there if it is new to 1.4?
Nevermind. I know why. I ran ./upgrade and forgot to use sudo first. So it probably ran that line before it errored out with a permission issue.
It happens! Let me know if you run into any further issues!
