Should we worry about this lot?
Applying NDOUtils patch level 103
ALTER TABLE `nagios_logentries` DROP INDEX `logentry_time_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'logentry_time_2'; check that column/key exists ALTER TABLE `nagios_logentries` DROP INDEX `logentry_data_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'logentry_data_2'; check that column/key exists ALTER TABLE `nagios_logentries` DROP INDEX `instance_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'instance_id_2'; check that column/key exists ALTER TABLE `nagios_statehistory` DROP INDEX `state_time_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'state_time_2'; check that column/key exists ALTER TABLE `nagios_statehistory` DROP INDEX `object_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'object_id_2'; check that column/key exists ALTER TABLE `nagios_notifications` DROP INDEX `start_time_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'start_time_2'; check that column/key exists ALTER TABLE `nagios_notifications` DROP INDEX `object_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'object_id_2'; check that column/key exists ALTER TABLE `nagios_notifications` DROP INDEX `instance_id_2` ;
ALTER TABLE `nagios_contactnotifications` DROP INDEX `notification_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'notification_id_2'; check that column/key exists ALTER TABLE `nagios_contactnotifications` DROP INDEX `contact_object_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'contact_object_id_2'; check that column/key exists ALTER TABLE `nagios_contactnotificationmethods` DROP INDEX `contactnotification_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'contactnotification_id_2'; check that column/key exists ALTER TABLE `nagios_objects` DROP INDEX `objecttype_id_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'objecttype_id_2'; check that column/key exists ALTER TABLE `nagios_objects` DROP INDEX `name1_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'name1_2'; check that column/key exists ALTER TABLE `nagios_objects` DROP INDEX `name2_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'name2_2'; check that column/key exists ALTER TABLE `nagios_objects` DROP INDEX `is_active_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'is_active_2'; check that column/key exists ALTER TABLE `nagios_timedeventqueue` DROP INDEX `queued_time_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'queued_time_2'; check that column/key exists ALTER TABLE `nagios_timedevents` DROP INDEX `queued_time_2` ;
SQL: SQL Error [ndoutils] :</b> Can't DROP 'queued_time_2'; check that column/key existsNDOUtils patched to level 103 successfully.
Architechure: x86_64
Nagios Core 3.4.1
Installation: Manual
SSL Enabled: Yes
# Nagios XI version information
full=2012R1.4
major=2012
minor=R1.4
releasedate=2013-01-16
release=304
