I have two exchange servers that the drives went into alert mode last night.
After the nightly backup the drives now have plenty of free space but nagios is alerting that they still
are full? The checks show updated times...logs show it checking servers....repaired database....
restarting agents on Servers....set refresh on template and the two services showing incorrectly?
Where should I look next?
commandline results
/check_nt -H 10.x.x.x -s "" -p 12489 -v USEDDISKSPACE -l T -w 90 -c 95
T:\ - total: 39.87 Gb - used: 38.67 Gb (97%) - free 1.20 Gb (3%) | 'T:\ Used Space'=38.67Gb;35.88;37.88;0.00;39.87
Actual Disk Usage on Server
[img][/img]
but actual command is
check_xi_service_nsclient $USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$
Arg 2 USEDDISKSPACE
Arg 3 -l T -w 90 -c 95
Nagiosxi reporting incorrect disk space usage
Re: Nagiosxi reporting incorrect disk space usage
What checks are you using to relay this information?
Does check_nt use a tmp file somewhere?
When you run the check from the command line, does it report the correct value? Can you run the actual command and show the output? (Hide the sensitive data)
For example:
Try running the following commands and see if this is going to help:
For example:
/usr/local/nagios/libexec/check_nt -H <IP_address> -s "<password>" -p 12489 -v USEDDISKSPACE -l C -w 90% -c 95%Code: Select all
service nagios stop
killall -9 nagios
service ndo2db stop
service ndo2db start
service nagios startBe sure to check out our Knowledgebase for helpful articles and solutions!
Commandline results were incorrect.... they were included previously but rebooted the servers last night and
all is correct today....Gremlins maybe?
Let us know if you have any more issues.
