I dont see any data in performance graphs for /var and /usr in any of my servers.
Is this something Nagios does not do or did i configure anything wrong
No data of performance graphs for /var and /usr
srikanth.kallu
Re: No data of performance graphs for /var and /usr
The standard check can check mount points, not directories. Usually, /var & /usr are directories under /
srikanth.kallu
Ok, Thank You
