Will features/Component in Nagios XI depend on JDK version
bojha
Post by bojha »
Hi All,
We are using Nagios XI 2011R1.9 which is running in RHEL 5 and now we are planning to Upgrade JDK 1.6 to JDK 1.7 across the organization. Since many peoples are using the Nagios XI UI So, we need to know like is there any component/Plugin/dependencies or any browser specific nagios uses which will be affected by this upgrade.
Thanks in advance
Re: Will features/Component in Nagios XI depend on JDK versi
Post by slansing »
Not that we are aware of, you should be fine updating that.. the only thing which really uses much Java is the alert stream but that is a self contained .jar.
bojha
Post by bojha »
Thanks for your reply...
