Hello. I upgraded to 2012R1.4 today via the upgrade script (followed instructions on Nagios site) and now my service or host detail will not load. The little wheel just keeps spinning.
I am running CentOS release 6.2 (Final) - this was the VM image provided by Nagios, updated using yum.
Kernel 2.6.32-279.19.1.e16,x86_64
I have rebooted the server, no change. Unfortunately my knowledge of linux is pretty low, I apologize. Can someone point me in the right direction to troubleshoot this??
Thanks much.
Service detail won't load after 1.4 upgrade
GEAviation-PBN
Re: Service detail won't load after 1.4 upgrade
Did you try right-click->Reload, while holding the "Shift" button? What browser are you using?
GEAviation-PBN
Yes I did. I am using IE9. I will try from a different browser just in case.
GEAviation-PBN
Ok, the problem is with IE9. Everything works fine in Chrome. Thank you.
It may also work in the IE if you change to compatibility mode.
