Not able to change configuration changes
I als0 tried this from CCM, but not able to save there as well.
cannot save configuration changes
srikanth.kallu
Re: cannot save configuration changes
Click on 'View the latest configuration snapshots' and click on the view output button. This will give you info as to what it errored out on. I just had one recently where I had to delete the service, save the config, then re-add the service. Not sure what happened as that client/service had been configured for some time now. If that doesnt work post the log.
kruserm is correct, you can also go to Configure -> CCM -> Tools -> Write config files
and click
Write
Verify
Look to see what the error is, and fix the error before proceeding.
and click
Write
Verify
srikanth.kallu
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'check filesize' on host 'b4sl01'
Error: Could not register service (config file '/usr/local/nagios/etc/services/b4sl01.cfg', starting on line 30)
I think i tried to edit this file which i shouldnt, I was trying to define a service there whch i was not successfull.
Now is there any way to delete that service because " Nagios QL will overwite all manual settings during the next update ".
You must set the following values on that service from the CCM then run the above steps again:
