You can't report on Solaris caches without Sun::Solaris::Kst
k42388
Post by k42388 »
Hi ,
I had issue to run following command to cature memory usage on solaris 10 server, please advise if anyone had ideal .
$ /usr/local/nagios/libexec/check_mem.pl -w 10 -c 5 -f -C
You can't report on Solaris caches without Sun::Solaris::Kstat available!
Thanks in advance.
Kenny
Re: You can't report on Solaris caches without Sun::Solaris:
Post by slansing »
Inside the plugin we find this:
eval "use Sun::Solaris::Kstat";
        if ($@) { #Kstat not available
It appears you must have the Sun::Solaris::Kstat perl module installed via CPAN.
