Here is the output.
COMMAND: /usr/local/nagios/libexec/check_nrpe -H 10.149.149.15 -t 30 -c check_mem -a '-w 20 -c 10'
OUTPUT: WARNING - 72 / 1010 MB (%) Free Memory, Used: 938 MB, Shared: 0 MB, Buffers: 347 MB, Cached: 518 MB | total=1010MB free=72MB used=938MB shared=0 buffers=347MB cached=518MBWhat version of Nagios XI are you using? Nagios XI 2012R1.3
Linux Distribution and version? centos 6.3
32 or 64bit? 32bit
VMware Image or Manual Install of XI? VMware Image
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? none
