this is useless :
Starting nagios:+ /usr/sbin/nagios -v /etc/nagios/nagios.cfg
+ '[' 254 -eq 0 ']'
+ echo 'CONFIG ERROR! Start aborted. Check your Nagios configuration.'
Have /usr/sbin/nagios -v /etc/nagios/nagios.cfg PRINT A MES
jpdonnelly
jpdonnelly
Re: Have /usr/sbin/nagios -v /etc/nagios/nagios.cfg PRINT A
Yeah, some packaged installations of Nagios hijacked the -v flag to bypass all of the useful information. I generally recommend always using a source install of Nagios if you can, that way the commands will reflect the documentation.
