Path not found error, v. 2009R1.3C
I just upgraded to v. 2009R1.3C and i'm getting path not found on many of the links.
Re: Path not found error, v. 2009R1.3C
Could you identify a couple of specific links that aren't working and also paste in the link location that these broken links are trying to access?
Try holding shift + reloading your browser to clear out any old data from your cache.
I get this error if I click on any of the header names to sort the data, when the "Host Detail", "Service Detail" tables are shown.
Not Found
The requested URL /nagiosxi/includes/components/xicore/http://nagios/nagiosxi/includes/compone ... status.php was not found on this server.
Apache/2.2.3 (CentOS) Server at nagios Port 80
Not Found
Update:I copied the link it's trying to go to
http://nagios/nagiosxi/includes/components/xicore/http%3A%2F%2Fnagios%2Fnagiosxi%2Fincludes%2Fcomponents%2Fxicore%2Fstatus.php?sortby=service_description&sortorder=desc&host=&hostgroup=&servicegroup=&records=100&page=1&search=&hostattr=0&serviceattr=0&hoststatustypes=0&servicestatustypes=28&show=services
I see the problem, it uses the host name and path 2 times.
If i manually delete the substring "http%3A%2F%2Fnagios%2Fnagiosxi%2Fincludes%2Fcomponents%2Fxicore%2F" then the link works properly.
Original URL:
Corrected URL:
Original URL:
http://nagios/nagiosxi/includes/components/xicore/xicore%2Fstatus.php?sortby=service_description&sortorder=desc&host=&hostgroup=&servicegroup=&records=100&page=1&search=&hostattr=0&serviceattr=0&hoststatustypes=0&servicestatustypes=28&show=services
Let me find out what the updates did for 1.3C and if this is a bug on our end....
Yeah, this is a bug specific to this release. I'll report it on the tracker...
Tracker url
http://tracker.nagios.com/view.php?id=86
Tracker url
Thanks.
For the reply.
For the reply.
Same problem here - column headers and arrows does not work properly, very frustrating to get bugs like this 2nd release in a row (continue button in 13.B CCM and now even much worse). Hopefully it will be fixed ASAP.
kariroman,
I feel your frustration, however could you please start a new topic to discuss this new issue. I assume you've upgraded(to 1.3D) to correct the continue button, but are now having issues sorting tables.
