check free disk space
Hi
I am using Nagios command (check_nt!USEDDISKSPACE!-l f -w 90 -c 95) to send alert if used space is over 90% / 95%).
I am now looking into setting up alerts if free disk space is lower than say 5GB. I believe Nagios core is not able to do it but a script or plug-in could be used to do that.
I wonder if anyone has a script/ plug-in that they can share which can send alerts based on free disk space integer.
Thanks.
Thanks.
Re: check free disk space
You cannot do this with check_nt but you can with check_nrpe (using NSClient). You would use something like this
http://www.nsclient.org/nscp/wiki/Check ... ze/samples
check_nrpe -H IP -p 5666 -c CheckDriveSize -a ShowAll MinWarnFree=10% MinCritFree=5G Drive=c:Re: check free disk space
Hi scottwilkerson
Thank you for taking time to reply - apologies that it took me a while to work on this.
When I run the command you provided from the terminal I get the following:
# ./check_nrpe -H <xxx.xxx.xxx.xxx> -p 5666 -c CheckDriveSize -a ShowAll MinWarnFree=10% MinCritFree=5% Drive=c:
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
I (0,4,1,66 2012-11-18) seem to be doing fine...
verifies that check_nrpe is available is is able to reach the host.
Do you know which option may not be allowed and how to fix it?
THANKS!
THANKS!
Have you checked the allow arguments option? It is located within the configuration file "NSC/nsclient.ini" and should be titled along the lines of:Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
allow_argumentsRe: check free disk space
Hi
Thank you for replying and pointing me to the correct direction. I was able to made necessary changes to the config file and now I am able to run the following command from terminal and get the expected output.
I am fairly new to Nagios and when I try to integrate it into Nagios I run into issues. Do you know what is the missing part of the puzzle?
In my command.ini file I have added
in my windows.cfg file I have added
To above Nagios is not happy. Do you know what is needed?
./check_nrpe -H <my host ip address> -p 5666 -c CheckDriveSize -a ShowAll MinWarnFree=10% MinCritFree=5G Drive=f:
command_name CheckDriveSize
command_line check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckDriveSize -a ShowAll MinWarnFree=$ARG2$ MinCritFree=5G Drive=c:
host_name <my host name>
service_description C:\ Drive Space
check_command CheckDriveSize c:,5G!10%
I think I have spotted the problem, in your command definition change the command_line to the following:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ -a ShowAll MinWarnFree=$ARG2$ MinCritFree=5G Drive=c:Code: Select all
check_command check_nrpe!CheckDriveSize!15!Re: check free disk space
Hi Slansing
The changes you recommended has not fixed the issue. After making the changes when I run pre flight test I get the error:
Error: Service check command 'check_nrpe' specified in service 'C:\ Drive Space' for host '<myhostname>' not defined anywhere!
If I commend out the service_description line in the windows.cfg then I don't get any error but I don't receive any alerts either.
Do you know if I need to define service_description at another place first?
Thanks!!!
Thanks!!!
Hi happy,
In your command.ini (command.ini is on the nagios server?) you have the following, correct?
So in your windows.cfg you should have the following:
In command.ini you define a "command_name", which is used for the "check_command" in the windows.cfg. The format of "check_command" is normally "command_name!<ARG1>!<ARG2>.....".
I hope this is helpful, I'm assuming your command.ini is on your nagios machine.
Kind Regards,
Gary Shergill
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ -a ShowAll MinWarnFree=$ARG2$ MinCritFree=5G Drive=c:
}Code: Select all
check_command CheckDriveSize!CheckDriveSize!10%
}I hope this is helpful, I'm assuming your command.ini is on your nagios machine.
Kind Regards,
Gary Shergill
Doh! How did I not see that... I must have ran out of coffee. Thank's for the input as always Gshergill!
Hi gshergill and Slansing
Thank you for all your help. I was able to get the required results and configured it as required. I currently have:
How can I change the command_line 'Drive=c' into argument so that I am able to check multiple drive letters with the same command_line?
I tried the following but it did not work and I am not able to figure it out
I appreciate your time!
host_name <myhostname>
check_command CheckDriveSize!CheckDriveSize!5G
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ -a ShowAll MinWarnFree=$ARG2$ Drive=$ARG3$ MinCritFree=5G
check_command CheckDriveSize!CheckDriveSize!c:!CheckDriveSize!5G
