Running configuration check... FAILED! Reload aborted
bsimpson
Post by bsimpson »
I am new to Nagios and need assistance. This morning we had a host we needed to disable from "/usr/local/nagios/etc/hosts/hosts.cfg", I disabled the host by indenting it out:
#define host{
# use ava-host ; Name of host template to use
# host_name AVATERM8
# alias Term8
# address 192.168.155.27
Saved the configuration file then I rebooted the server with a "sudo reboot". Once the server came back up I logged into the Nagios GUI (192.168.155.19/nagios) and encountered the following error when attempting to view service detail:
"Whoops! Error: Could not read host and service status information!"
I then attempted to manually start nagios with the following command "/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg" to no avail. Attempted to restart nagios with the following command "sudo invoke-rc.d nagios reload" this gave the following error in the output:
"Running configuration check... FAILED! Reload aborted. Check your Nagios configuration.
invoke-rc.d: initscript nagios, action "reload" failed."
It does not appear nagios can start and I am at a loss to why. Here are the current Nagios processes running:
administrator@Intranet:/usr/local/nagios/etc/hosts$ ps axu | grep nagios
nagios 5064 0.0 0.1 10872 5840 ? Ss 10:13 0:00 /usr/bin/perl -w /usr/sbin/nagiosgrapher
nagios 7373 0.0 0.0 13964 1484 ? SNsl 11:36 0:00 /usr/sbin/nagios2 -d /etc/nagios2/nagios.cfg
1000 9554 0.0 0.0 3004 752 pts/1 R+ 13:10 0:00 grep nagios
Re: Running configuration check... FAILED! Reload aborted
Post by slansing »
Lets first run a config check with the following and report the output back here:
It is possible something was inadvertently changed with the host and it's relationships.
bsimpson
Post by bsimpson »
Ok, ran "/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg" here is the output:
Nagios 2.5
Copyright (c) 1999-2006 Ethan Galstad (http://www.nagios.org)
Last Modified: 07-13-2006
License: GPL
Reading configuration data...
Error: Could not find any host matching 'AVATERM8'
Error: Could not expand member hosts specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 7)
abrist
Red Shirt
Post by abrist »
I t looks like the host you commented out exists in at least one other place. Remove it from the hostgroups.cfg file and try to verify again.
Post by slansing »
We are going to continue support for this via our ticketing system that you emailed. I will keep the thread open so that we can post what the solution was for the future.
