Port bandwidth status OK but no device on that port?!
xpertech
Post by xpertech »
Port bandwidth status OK but there is actually no device on that port?
The "Status" should not display "OK" when there is no device link to that port.
Re: Port bandwidth status OK but no device on that port?!
The Bandwidth is only going to report Warning or Critical if the port is using more bandwidth than the threshold.
the status reports is there isn't something plugged in, which it is...
