Check will not run
BanditBBS
Check will not run
Post by BanditBBS »
We had our SAN crash and when NagiosXI database came back up, items started gettign checked again and showing up. However, one service is reporting:
(service check orphaned, is the mod-gearman worker on queue 'service' running?)
If I schedule a check, it never runs. This check is just seeing if SSH is running on the server. It is configured like the other 10 services for that server, no special service group or anything.
Any clues?
edit: Updated thread subject
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS
Re: orphaned check
Post by BanditBBS »
So I made it inactive, applied setting, reactivated it, applied settings and the check still won't run. Now stuck in pending state.
Re: Check will not run
Post by slansing »
This sounds like an issue that is caused by the job not being killed off when it was told to, is it feasible for you to restart the worker and the mod gearman server? Not the box, just the service.
BanditBBS
Post by BanditBBS »
That was it, I restarted the worker and gearmand and it seems ok now.
Post by slansing »
Excellent, no problem.
