"Sample MRTG configuration file snippets for graphing various Nagios performance statistics can be found in the mrtg.cfg file located in the sample-config/ subdirectory of the Nagios distribution."
Unfortunately, on our Nagios server I don't see this "sample-config/" subdirectory. Where can I get these additional snippets?
Graphing Performance Info With MRTG
Re: Graphing Performance Info With MRTG
Can you maybe give us a little more context as to the document you're quoting from?
Performance graphs are built in Nagios XI. This particular document refers to Nagios Core. You will find the "sample-config" directory in the Nagios Core source code.
