cgi permissions
Locutus
cgi permissions
Post by Locutus »
i´m trying to grant permissions to specific groups in the cgi.cfg.
Apache Authentication is working with PAM / winbind against an AD.
Only Users in the group nagios_admins can access the webpage and this is working without problems.
In Service / Host Details i get the error "It appears as though you do not have permission to view information for any of the services you requested..."
I´ve figured out that the problem doesn´t exist if i add the user to the "authorized_for_system_information" and the other similar options.
Is it possible to add a group instead of the user?
If i add the nagios_admins group it doesn´t work.
Thanks in advance
mguthrie
Re: cgi permissions
Post by mguthrie »
As far as I know the cgi.cfg file only grants permissions to users...
http://nagios.sourceforge.net/docs/3_0/configcgi.html
http://nagios.sourceforge.net/docs/3_0/cgiauth.html
