graphs stopped working after upgrade and update to 2012R1.5b
marquetteu
after doing a yum update and then an update to 2012R1.5b all my graphs no longer show any data saying nan for all values.
Please advise
Please advise
Re: graphs stopped working after upgrade and update to 2012R
Could you post the following log files in a code wrap?
tail -50 /usr/local/nagios/var/perfdata.log
tail -50 /usr/local/nagios/var/npcd.logFormer Nagios employee
marquetteu
$ tail -50 /usr/local/nagios/var/perfdata.log
2013-01-30 03:14:53 [25682] [0] *** Timeout while processing Host: "its-mjdev3" Service: "CPU"
2013-01-30 03:14:53 [25682] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 03:19:31 [28455] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 03:19:31 [28455] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 03:19:31 [28455] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 03:19:31 [28455] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1359537561.perfdata.service-PID-28455 deleted
2013-01-30 03:19:31 [28455] [0] *** Timeout while processing Host: "its-gporadev1" Service: "CPU"
2013-01-30 03:19:31 [28455] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 03:34:19 [3883] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 03:34:19 [3883] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 03:34:19 [3883] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 03:34:19 [3883] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1359538446.perfdata.service-PID-3883 deleted
2013-01-30 03:34:19 [3883] [0] *** Timeout while processing Host: "its-psoradev2" Service: "CPU"
2013-01-30 03:34:19 [3883] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 04:16:24 [27945] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 04:16:24 [27946] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 04:16:24 [27945] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 04:16:24 [27946] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 04:16:24 [27945] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 04:16:24 [27946] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 04:16:24 [27945] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1359540966.perfdata.host-PID-27945 deleted
2013-01-30 04:16:24 [27946] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1359540966.perfdata.service-PID-27946 deleted
2013-01-30 04:16:24 [27945] [0] *** Timeout while processing Host: "vs-empsnd" Service: "_HOST_"
2013-01-30 04:16:24 [27946] [0] *** Timeout while processing Host: "vs-oemstg" Service: "DiskIO"
2013-01-30 04:16:24 [27945] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 04:16:24 [27946] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 04:33:32 [4713] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 04:33:32 [4713] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 04:33:32 [4713] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 04:33:32 [4713] [0] *** TIMEOUT: Could not delete /usr/local/nagios/var/spool/perfdata//1359542001.perfdata.host-PID-4713:No such file or directory
2013-01-30 04:33:32 [4713] [0] *** Timeout while processing Host: "" Service: ""
2013-01-30 04:33:32 [4713] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 04:33:32 [4714] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 04:33:32 [4714] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 04:33:32 [4714] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 04:33:32 [4714] [0] *** TIMEOUT: Could not delete /usr/local/nagios/var/spool/perfdata//1359542001.perfdata.service-PID-4714:No such file or directory
2013-01-30 04:33:32 [4714] [0] *** Timeout while processing Host: "its-oradev1" Service: "Paging"
2013-01-30 04:33:32 [4714] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 12:00:08 [29495] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 12:00:08 [29495] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 12:00:08 [29495] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 12:00:08 [29495] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1359568791.perfdata.service-PID-29495 deleted
2013-01-30 12:00:08 [29495] [0] *** Timeout while processing Host: "its-mjprod1" Service: "CPU"
2013-01-30 12:00:08 [29495] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-30 21:50:14 [5415] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-30 21:50:14 [5415] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-30 21:50:14 [5415] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-30 21:50:14 [5415] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1359604191.perfdata.service-PID-5415 deleted
2013-01-30 21:50:14 [5415] [0] *** Timeout while processing Host: "its-mjprod2" Service: "CPU"
2013-01-30 21:50:14 [5415] [0] *** process_perfdata.pl terminated on signal ALRM
$ tail -50 /usr/local/nagios/var/npcd.log
[01-27-2013 01:06:26] NPCD: WARN: MAX load reached: load 10.300000/10.000000 at i=0[01-27-2013 01:07:08] NPCD: ERROR: Executed command exits with return code '7'
[01-27-2013 01:07:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270369.perfdata.host'
[01-27-2013 01:07:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270335.perfdata.host'
[01-27-2013 01:07:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270320.perfdata.service'
[01-27-2013 01:07:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270335.perfdata.service'
[01-27-2013 01:07:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270320.perfdata.host'
[01-27-2013 01:07:08] NPCD: WARN: MAX load reached: load 12.200000/10.000000 at i=7[01-27-2013 01:07:23] NPCD: WARN: MAX load reached: load 12.880000/10.000000 at i=7[01-27-2013 01:08:58] NPCD: ERROR: Executed command exits with return code '7'
[01-27-2013 01:08:58] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270370.perfdata.service'
[01-27-2013 01:08:58] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270369.perfdata.service'
[01-27-2013 01:09:13] NPCD: WARN: MAX load reached: load 25.890000/10.000000 at i=0[01-27-2013 01:09:28] NPCD: WARN: MAX load reached: load 20.390000/10.000000 at i=1[01-27-2013 01:09:43] NPCD: WARN: MAX load reached: load 16.030000/10.000000 at i=1[01-27-2013 01:09:58] NPCD: WARN: MAX load reached: load 14.580000/10.000000 at i=1[01-27-2013 01:11:08] NPCD: WARN: MAX load reached: load 32.400000/10.000000 at i=1[01-27-2013 01:11:23] NPCD: WARN: MAX load reached: load 27.600000/10.000000 at i=1[01-27-2013 01:11:38] NPCD: WARN: MAX load reached: load 21.690000/10.000000 at i=1[01-27-2013 01:11:53] NPCD: WARN: MAX load reached: load 17.810000/10.000000 at i=1[01-27-2013 01:12:46] NPCD: WARN: MAX load reached: load 23.460000/10.000000 at i=1[01-27-2013 01:13:01] NPCD: WARN: MAX load reached: load 18.270000/10.000000 at i=1[01-27-2013 01:13:16] NPCD: WARN: MAX load reached: load 14.220000/10.000000 at i=1[01-27-2013 01:13:31] NPCD: WARN: MAX load reached: load 11.070000/10.000000 at i=1[01-27-2013 01:14:04] NPCD: ERROR: Executed command exits with return code '7'
[01-27-2013 01:14:04] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359270386.perfdata.service'
[01-29-2013 17:00:55] NPCD: Caught Termination Signal - Hasta la vista... baby
[01-29-2013 17:02:46] NPCD: npcd Daemon (0.4.14) started with PID=5024
[01-29-2013 17:02:46] NPCD: Please have a look at 'npcd -V' to get license information
[01-29-2013 17:02:46] NPCD: HINT: load_threshold is enabled - ('10.000000')
[01-30-2013 02:59:25] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 02:59:25] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359536346.perfdata.service'
[01-30-2013 03:00:31] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 03:00:31] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359536421.perfdata.service'
[01-30-2013 03:04:15] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 03:04:15] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359536631.perfdata.host'
[01-30-2013 03:10:11] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 03:10:11] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359536991.perfdata.service'
[01-30-2013 03:14:53] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 03:14:53] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359537276.perfdata.service'
[01-30-2013 03:19:31] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 03:19:31] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359537561.perfdata.service'
[01-30-2013 03:34:19] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 03:34:19] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359538446.perfdata.service'
[01-30-2013 04:16:24] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 04:16:24] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359540966.perfdata.service'
[01-30-2013 04:16:24] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359540966.perfdata.host'
[01-30-2013 04:33:32] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 04:33:32] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359542001.perfdata.host'
[01-30-2013 04:33:32] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359542001.perfdata.service'
[01-30-2013 12:00:08] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 12:00:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359568791.perfdata.service'
[01-30-2013 21:50:14] NPCD: ERROR: Executed command exits with return code '7'
[01-30-2013 21:50:14] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1359604191.perfdata.service'
[01-31-2013 08:51:58] NPCD: Caught Termination Signal - Hasta la vista... baby
[02-04-2013 11:04:07] NPCD: npcd Daemon (0.4.14) started with PID=5082
[02-04-2013 11:04:07] NPCD: Please have a look at 'npcd -V' to get license information
[02-04-2013 11:04:07] NPCD: HINT: load_threshold is enabled - ('10.000000')
Can you run the following and then tail the logs again?:
Edit /usr/local/nagios/etc/pnp/npcd.cfg:
Change the load threshold:
load_threshold = 30.0Code: Select all
service npcd restart-
marquetteu
[02-04-2013 14:47:54] NPCD: Caught Termination Signal - Hasta la vista... baby
[02-04-2013 14:47:54] NPCD: npcd Daemon (0.4.14) started with PID=22216
[02-04-2013 14:47:54] NPCD: Please have a look at 'npcd -V' to get license information
[02-04-2013 14:47:54] NPCD: HINT: load_threshold is enabled - ('30.000000')
Can you post your system load?
Report the output of the following:
At this point give the system a minute to spool a bit and check current system load:
Then restart npcd and check the logs again, we may have to increase the threshold more:
service npcd stopCode: Select all
killall npcdCode: Select all
topCode: Select all
service npcd start-
Can you run and report back
Also lets increase the TIMEOUT in /usr/local/nagios/etc/pnp/process_perfdata.cfg to 15
ls -l /usr/local/nagios/var/spool/perfdata|wc -l-
marquetteu
[02-05-2013 08:57:31] NPCD: Caught Termination Signal - Hasta la vista... baby
[02-05-2013 09:00:14] NPCD: npcd Daemon (0.4.14) started with PID=18577
[02-05-2013 09:00:14] NPCD: Please have a look at 'npcd -V' to get license information
[02-05-2013 09:00:14] NPCD: HINT: load_threshold is enabled - ('30.000000')
$ ls -l /usr/local/nagios/var/spool/perfdata|wc -l
3
thanks!
Adam
Did you run these log tails after you changed the timeout? It looks like they still have the old timeout rate, after changing it what do the logs show now?
marquetteu
yes this was post timeout change. I just looked at the logs and nothing has been added since i restarted npcdslansing wrote:Did you run these log tails after you changed the timeout? It looks like they still have the old timeout rate, after changing it what do the logs show now?
