Where does oscp commands get logged?
rsegebre
Post by rsegebre »
Good Afternoon,
I am currently in the process of testing a distributed monitoring solution using nsca/send_nsca which a NagiosXI box as a master and multiple Nagios Core boxes as slaves. The problem I've encountered so far is that Nagios Core doesn't seem to be executing the ocsp/ochp commands I specified for services or hosts.
The NagiosXI box does receive objects even if they are not configured when I run the my ocsp/ochp commands as the nagios or root user. But when I set Nagios Core to automatically submit results for a group of hosts nothing happens, and I cannot find where does it get logged.
After some searching I still couldn't figure out where does send_nsca and oscp get logged on a Nagios Core CentOS installation? I can see nsca getting logged in two places /var/log/messages and /etc/usr/local/nagios/var/nagios.debug with logging for everything at a detailed level.
I have the following configuration on the Nagios Core box:
#nagios.cfg
obsess_over_services=1
ocsp_command=submit_service_check
obsess_over_hosts=1
ochp_command=submit_host_check
#sql-host.cfg
        use                     windows-server
        host_name          sql-server001
        alias                   sql-server001
        address               123.4.6.7
        obsess_over_host        1
        obsess_over_service             1
        service_description     PING
        check_command           check_ping!100.0,20%!500.0,60%
Summary:
* Where does ocsp and ochp log everytime they run?
Info:
* Master: Nagios XI: receives unconfigured objects properly through nsca, tested by running the ocsp/ochp commands manually from slave hosts as the nagios and root users.
* Slaves: Nagios Core boxes: sends data using send_nsca, and obsesses over a host only simply for testing purposes.
Thank you for your time!
rsegebre
Re: Where does oscp commands get logged?
Post by rsegebre »
I actually figured this out. So I was simply logging to much information to nagios.debug to the point that it got rotated very quickly since it reached the size limit. So I reduced logging on debug to only log commands and did a very detailed info, and I did see it executing the ocsp/ochp commands and it complained about file permissions for send_nsca.cfg which is something I thought I had checked a couple times.
Anyways, sorry for the post.
Nagios debug logging is awesome! Helps you troubleshoot anything!!!
Post by slansing »
Haha yes it is very useful! Glad to hear you got it all sorted out, thanks for letting us know!
