Display Issues using Internet Explorer 9
allenwallach
Post by allenwallach »
When I log into our server running Nagios XI and click on Host Details, it just sits there with those little wheels spinning and never displays anything. If I click on compatibility mode and then click on Host Details everything is display perfectly. Is there settings that need to be checked in Internet Explorer 9 instead of using compatibility mode?
Re: Display Issues using Internet Explorer 9
That is correct, IE 9 must be in compatibility mode for the Nagios XI page. It should remember your setting on a per site basis.
allenwallach
Is putting it in compatibility mode just a temporary fix or is it permanent?
Post by slansing »
Correct, Microsoft changed the way some of the internal extensions work within IE and it is playing havoc with quite a few things. We are currently looking for workarounds.
mguthrie
Post by mguthrie »
What version of Nagios XI are you currently using?
Starting in 1.5+ we have code added to tell IE what mode to display in to work properly for each of the pages.
