The bb map display all monitoring items in a matrix table.
Is there a way to export monitoring items and alert contacts? After setup hundreds of monitoring items, I want to check how many monitoring items and who is going to be contact when alert? bb map is good for viewing monitoring items, but lack contacts information.
Is there a way to export monitoring items & alert contacts?
Re: Is there a way to export monitoring items & alert contac
If you had an Enterprise Edition or at least started a trial, you could view all contacts/contact groups and their relationships to hosts/services via the Bulk Modification Tool:
Core Config Manager->Tools->Bulk Modifications->Remove Contact (or a Contact Group)->Make a choice from the drop-down menu and click on "Find Relationships"
You can export monitoring information via Admin -> Manage Components -> Backend API
As for the alert contacts, exactly what you described is on our internal TODO list of features to add.
