[Tue Feb 05 14:43:51 2013] [error] [client xxx.xxx.xxx.xxx] PHP Notice: Undefined variable: class in /usr/local/nagiosxi/html/includes/components/opscreen/merlin.php on line 275, referer: http://lnttavmnag1/nagiosxi/includes/components/opscreen/opscreen.php
Line 275 of /usr/local/nagiosxi/html/includes/components/opscreen/merlin.php
Which version of XI is this for? I see that we have some line changes with the newest one, and would like to be sure that it is resolved correctly.
We run behind a proxy and I have to jump through hoops to open it back up and let someone else run the update. Thus the reason I don't have the ability to see when a new update is present via the Nagios interface.
I should note that the issue came about when I started to notice that the 'Whoops!' screen when I click on Tactical Overview, but when I click on Home (where I have Tactical Overview set as my home screen), it will display just fine.
while ($row = mysql_fetch_array($result)) {
$class = "";
Or you can wait for revision 1.6, I would not suggest upgrading to 1.5b as it has a few bugs that are nice if you can avoid them.
edit: 277 compared to my current revision. It would probably be 270ish for you.
