Exporting check data to another systems in real time
hotdealdave
Post by hotdealdave »
My organization is currently planning to impliment a "Monitor of Monitors" system, which is to display statuses of systems monitored by Nagios, as well as several other monitors to provide managers and Execs a wholistic view of IT infrastructure health. The product has not been decided on yet.
I have been asked to find out what method or methods Nagios XI can use to export check results to another system, and if there is a preferred way. We would want to minimize network traffic and performance impact on the Nagios XI server.
Any thoughts from the support staff?
abrist
Red Shirt
Re: Exporting check data to another systems in real time
Post by abrist »
This could be done multiple ways as XI is fairly extensible. You should take a look over the Component Development Document as it explains how to pull data from xi. You could use the backendargs to pull a full (or custom truncated) xml file from XI, listing host and service status, and send it to a different application.
There is a commercial product we offer called "Fusion" that acts as a front end for XI and core among others.
I assure you that other members of the support team would have other (probably better) ideas as well.
