Upgrade
tbarnett
Upgrade
Post by tbarnett »
This morning when I upgraded Nagios from ver 1.4, the upgrade check said the 1.5 was available. When I actually did the upgrade I got 1.6 installed.
When I did a check for the latest version again it said I needed an upgrade to version 1.5.
I thought you might want to change your logic test for version number available so I'm reporting it.
Tom
Tom Barnett
Senior Systems Administrator
Prime, inc.
2740 N. Mayfair Ave
Springfield, MO 65803
Re: Upgrade
Post by slansing »
I will be sure to bring this up, 1.6 was just released within 24 hours though so perhaps you barley missed the change. Thanks for the heads up though!
