Getting no graphs
David.adder
Getting no graphs
Post by David.adder »
Since yesterday, I'm not getting data in any graphs in the nagios web. I noticed this when I installed the tools to get netflow data in the Nagios Server.
To install this, I ran: "yum install rrdtool rrdtool-devel rrdutils perl-rrdtool -y" and from that moment I don't get graphs in Nagios
I don't know if this could affect the nagios graphs by any way.
[root@SRVBOXASDC1009 ~]# service npcd status
NPCD running (pid 2130).
[root@SRVBOXASDC1009 ~]# tail /usr/local/nagios/var/perfdata.log
2013-02-07 11:07:38 [12213] [0] *** TIMEOUT: Please check your npcd.cfg
2013-02-07 11:07:38 [12213] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1360231622-PID-12213 deleted
2013-02-07 11:07:38 [12213] [0] *** Timeout while processing Host: "SRVQUARRDDC1001" Service: "Ping"
2013-02-07 11:07:38 [12213] [0] *** process_perfdata.pl terminated on signal ALRM
2013-02-07 11:07:38 [12211] [0] *** TIMEOUT: Timeout after 15 secs. ***
2013-02-07 11:07:38 [12211] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-02-07 11:07:38 [12211] [0] *** TIMEOUT: Please check your npcd.cfg
2013-02-07 11:07:38 [12211] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1360231637-PID-12211 deleted
2013-02-07 11:07:38 [12211] [0] *** Timeout while processing Host: "AMPEREBCM" Service: "my_c_drive"
2013-02-07 11:07:38 [12211] [0] *** process_perfdata.pl terminated on signal ALRM
ll /usr/local/nagios/share/perfdata
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8154
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8154_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:30 ROCLAI8155
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8155_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:29 ROCLAI8156
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:27 ROCLAI8156_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8157
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8157_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:29 ROCLAI8159
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:27 ROCLAI8159_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:27 ROCLAI8161
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:29 ROCLAI8161_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:27 ROCLAI8162
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:29 ROCLAI8163
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8163_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8164
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:33 ROCLAI8164_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:29 ROCLAI8167
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8167_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8168
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8168_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:29 ROCLAI8169
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8169_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8170
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:30 ROCLAI8170_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8173
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:32 ROCLAI8173_EXTERNAL
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:28 ROCLAI8174
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:30 ROCLAI8174_External
drwxrwxr-x 2 nagios nagios 4096 feb 7 21:30 ROCLAI8175
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
4574 nagios 20 0 98.4m 10m 992 S 7.7 0.3 47:24.02 nagios
16873 root 20 0 15216 1224 812 R 3.8 0.0 0:00.03 top
1421 root 20 0 9200 560 408 S 1.9 0.0 0:06.28 irqbalance
1920 postgres 20 0 173m 1248 412 S 1.9 0.0 0:10.69 postmaster
1 root 20 0 19404 1488 1176 S 0.0 0.0 0:01.94 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root RT 0 0 0 0 S 0.0 0.0 0:04.04 migration/0
4 root 20 0 0 0 0 S 0.0 0.0 0:00.08 ksoftirqd/0
5 root RT 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
6 root RT 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/0
7 root RT 0 0 0 0 S 0.0 0.0 0:05.07 migration/1
8 root RT 0 0 0 0 S 0.0 0.0 0:00.00 migration/1
9 root 20 0 0 0 0 S 0.0 0.0 0:00.07 ksoftirqd/1
10 root RT 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/1
11 root RT 0 0 0 0 S 0.0 0.0 0:04.30 migration/2
You can see a couple of example, but this happend in all service/host:
Re: Getting no graphs
What is the load on your Nagios XI server?
Please, run the following commands and show us the output:
df -h
df -i
David.adder
Hi Lmiltchev,
df -i
S.ficheros Inodes IUsed IFree IUse% Montado en
/dev/mapper/vg_srvboxasdc1009-lv_root
12844496 202870 12641626 2% /
tmpfs 490615 1 490614 1% /dev/shm
/dev/sda1 128016 40 127976 1% /boot
/dev/mapper/vg_srvboxasdc1009-lv_home
2342912 20 2342892 1% /home
df -h
S.ficheros Size Used Avail Use% Montado en
194G 47G 137G 26% /
tmpfs 1,9G 0 1,9G 0% /dev/shm
/dev/sda1 485M 51M 409M 12% /boot
36G 176M 34G 1% /home
Is it normal de data got with the file perfdata.tar.gz?
mguthrie
Post by mguthrie »
Are you using rrdcached at all on this system?
David.adder
Hi mguthrie,
Actually it was, but I have checked this, and I've installed it again http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
Now the graphs are working.
Do you know how was possible that this were disabled or uninstalled?
Thank you so much!
mguthrie
Post by mguthrie »
Hard to say, but I'm guessing the new package installation may have wiped out your rrdcached config. Glad it's working now though!
