How 2 create Datasoure 2 monitor a solaris device via ssh
sathishakh
How to monitor solaris device using ssh in nagios. please help me in monitoring of cpu, swap, disk and uptime using ssh.
Re: How 2 create Datasoure 2 monitor a solaris device via ss
Have you read through the following document?
http://exchange.nagios.org/directory/Ad ... rd/details
sathishakh
thanks abrist. let me configure it and get back to u if i found any issue.
Excellent, let us know if you need help.
sathishakh
Hi Buddy,
after i followed the http://exchange.nagios.org/directory/Ad ... rd/details, i added the solaris device through ssh. there is a error like
Return code of 127 is out of bounds - plugin may be missing for Root Disk Space.
i have mentioned the following things to monitor Disk space in "Monitor the service with this command..."
check_xi_service_snmp_linux_storage!-C secret --v1c -m "^/$" -w 90 -c 95 -f!!!!!!!
Please help.
Please help.
Are you able to run the check command manually from the command line of your Nagios XI server? I would recommend doing this, though you will likely get the same error, in this case, make sure that the correct ports are opened and definitions made on the remote system. Also make sure that the plugin is in fact executable.
sathishakh wrote: check_xi_service_snmp_linux_storage!-C secret --v1c -m "^/$" -w 90 -c 95 -f!!!!!!!
"^/$"Upgrade XI
