Notification Options - Bulk Changes
BanditBBS
Post by BanditBBS »
Is there a reason "Notification Options" are not part of the bulk modifications tool? I want to remove the check next to "Scheduled Downtime" from all services.
Thanks!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS
Re: Notification Options - Bulk Changes
Post by BanditBBS »
After some investigating, it also looks like some wizards may have all options selected while some wizards only have some of the notification option selected. Is there a way to standardize this somewhere?
abrist
Red Shirt
Post by abrist »
There are a number of notifications options in the bulk modification tool. Unfortunately, there is no option to remove scheduled downtime in bulk.
BanditBBS wrote:After some investigating, it also looks like some wizards may have all options selected while some wizards only have some of the notification option selected. Is there a way to standardize this somewhere?
You could make a service template with the desired notification options and add the template to the service after you are completed with the wizard. Otherwise you would have to edit the php file for the corresponding wizard.
There is a feature request on our bug tracker:
http://tracker.nagios.com/view.php?id=267
Is this the functionality that you need?
BanditBBS
Post by BanditBBS »
lmiltchev wrote:There is a feature request on our bug tracker:
Simple answer, Nope :)
abrist wrote:You could make a service template with the desired notification options and add the template to the service after you are completed with the wizard. Otherwise you would have to edit the php file for the corresponding wizard.
But if by default the wizard sets the options on the services when they are created, doesn't the option on the service override any option in a template? The other easy fix is just to tell users to uncheck downtimes under their notification preferences on their account, right?
I am sorry - I misunderstood your question.
...doesn't the option on the service override any option in a template?
Yes, it would override it.
Yes, actually this is going to be easier to do (to modify the notification options on the user level), then doing it on the host/service level.
