No Metrics or Performance Graphs
Can someone point me in the right direction.
I have tried the FAQ points to try and resolve.
I have definetly got the Process perf data setting set to ON
Server ping graphs ok, and the Nagios server metrics work and graph, but all other services do not graph.
Re: No Metrics or Performance Graphs
Lets get some background, were they working up until last night? Are these all newly added hosts/services? What version of Nagios XI are you running on, as well as the distro it is installed on top of.
Nagios XI 2012R1.6
They have never worked since i started but havent had any time to follow up until now.
Its on top of the CentOS 6 VM template provided by Nagios.
Nagios XI 2012R1.6
CentOS 6 VM from Nagios
Graphs and metrics have never worked, just never had time to follow up until now.
Post a tail of the following files in a code wrap:
tail -50 /usr/local/nagios/var/perfdata.log
tail -50 /usr/local/nagios/var/npcd.logFormer Nagios employee
2013-01-21 11:11:53 [29452] [0] *** Timeout while processing Host: "resdc01.ds-s.com" Service: "_HOST_"
2013-01-21 11:11:53 [29452] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-21 11:12:20 [29491] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-21 11:12:38 [29491] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-21 11:12:38 [29491] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-21 11:12:38 [29491] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1358764178.perfdata.host-PID-29491 deleted
2013-01-21 11:12:38 [29495] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-21 11:12:38 [29491] [0] *** Timeout while processing Host: "dervhost01.ds-s.com" Service: "_HOST_"
2013-01-21 11:12:38 [29495] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-21 11:12:38 [29491] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-21 11:12:38 [29495] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-21 11:12:38 [29495] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1358764163.perfdata.service-PID-29495 deleted
2013-01-21 11:12:38 [29495] [0] *** Timeout while processing Host: "" Service: ""
2013-01-21 11:12:38 [29495] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-21 11:12:38 [29492] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-21 11:12:43 [29492] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-21 11:12:44 [29492] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-21 11:12:44 [29493] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-21 11:12:44 [29493] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-21 11:12:44 [29493] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-21 11:12:44 [29496] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-21 11:12:44 [29496] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-21 11:12:44 [29496] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-21 11:12:44 [29492] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1358764193.perfdata.service-PID-29492 deleted
2013-01-21 11:12:44 [29493] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1358764178.perfdata.service-PID-29493 deleted
2013-01-21 11:12:44 [29492] [0] *** Timeout while processing Host: "" Service: ""
2013-01-21 11:12:44 [29492] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-21 11:12:44 [29493] [0] *** Timeout while processing Host: "" Service: ""
2013-01-21 11:12:44 [29493] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-21 11:12:44 [29496] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1358764193.perfdata.host-PID-29496 deleted
2013-01-21 11:12:49 [29496] [0] *** Timeout while processing Host: "" Service: ""
2013-01-21 11:13:05 [29496] [0] *** process_perfdata.pl terminated on signal ALRM
2013-01-21 11:21:56 [4037] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-01-21 11:21:56 [4037] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-01-21 11:21:56 [4037] [0] *** TIMEOUT: Please check your npcd.cfg
2013-01-21 11:21:56 [4037] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1358764268.perfdata.host-PID-4037 deleted
2013-01-21 11:21:56 [4037] [0] *** Timeout while processing Host: "server2.domain.com" Service: "_HOST_"
2013-01-21 11:21:56 [4037] [0] *** process_perfdata.pl terminated on signal ALRM
2013-02-09 01:04:38 [30423] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-02-09 01:04:38 [30423] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-02-09 01:04:38 [30423] [0] *** TIMEOUT: Please check your npcd.cfg
2013-02-09 01:04:38 [30423] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1360371850.perfdata.host-PID-30423 deleted
2013-02-09 01:04:38 [30423] [0] *** Timeout while processing Host: "server1.domain.com" Service: "_HOST_"
2013-02-09 01:04:38 [30423] [0] *** process_perfdata.pl terminated on signal ALRM
2013-02-09 01:25:46 [425] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-02-09 01:25:46 [425] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-02-09 01:25:46 [425] [0] *** TIMEOUT: Please check your npcd.cfg
2013-02-09 01:25:46 [425] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1360373130.perfdata.host-PID-425 deleted
2013-02-09 01:25:46 [425] [0] *** Timeout while processing Host: "server.domain.com" Service: "_HOST_"
2013-02-09 01:25:46 [425] [0] *** process_perfdata.pl terminated on signal ALRM
[02-13-2013 15:48:57] NPCD: DEBUG: load 4.560000/10.000000
[02-13-2013 15:48:57] NPCD: ThreadCounter 2/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 15:48:57] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 15:48:57] NPCD: Have to wait: Filecounter = 3 - thread_counter = 2
[02-13-2013 15:48:57] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 15:49:12] NPCD: Found 3 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 15:49:12] NPCD: DEBUG: load 5.660000/10.000000
[02-13-2013 15:49:12] NPCD: ThreadCounter 0/5 File is .
[02-13-2013 15:49:12] NPCD: ThreadCounter 0/5 File is ..
[02-13-2013 15:49:12] NPCD: ThreadCounter 0/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 15:49:12] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 15:49:12] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 15:49:27] NPCD: Found 5 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 15:49:27] NPCD: DEBUG: load 7.800000/10.000000
[02-13-2013 15:49:27] NPCD: ThreadCounter 0/5 File is .
[02-13-2013 15:49:27] NPCD: ThreadCounter 0/5 File is ..
[02-13-2013 15:49:27] NPCD: ThreadCounter 0/5 File is 1360770546.perfdata.host
[02-13-2013 15:49:27] NPCD: Regular File: 1360770546.perfdata.host
[02-13-2013 15:49:27] NPCD: A thread was started on thread_counter = 0
[02-13-2013 15:49:27] NPCD: Processing file 1360770546.perfdata.host with ID -1215628432 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360770546.perfdata.host
[02-13-2013 15:49:27] NPCD: ThreadCounter 1/5 File is 1360770561.perfdata.host
[02-13-2013 15:49:27] NPCD: Processing file '1360770546.perfdata.host'
[02-13-2013 15:49:27] NPCD: Regular File: 1360770561.perfdata.host
[02-13-2013 15:49:27] NPCD: A thread was started on thread_counter = 1
[02-13-2013 15:49:27] NPCD: Processing file 1360770561.perfdata.host with ID -1227883664 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360770561.perfdata.host
[02-13-2013 15:49:27] NPCD: Processing file '1360770561.perfdata.host'
[02-13-2013 15:49:27] NPCD: ThreadCounter 2/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 15:49:27] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 15:49:27] NPCD: Have to wait: Filecounter = 3 - thread_counter = 2
[02-13-2013 15:49:27] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 15:49:42] NPCD: Found 3 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 15:49:42] NPCD: DEBUG: load 10.150000/10.000000
[02-13-2013 15:49:42] NPCD: WARN: MAX load reached: load 10.150000/10.000000 at i=0[02-13-2013 15:49:57] NPCD: DEBUG: load 11.340000/10.000000
[02-13-2013 15:49:57] NPCD: WARN: MAX load reached: load 11.340000/10.000000 at i=1[02-13-2013 15:50:12] NPCD: DEBUG: load 8.970000/10.000000
[02-13-2013 15:50:12] NPCD: ThreadCounter 0/5 File is ..
[02-13-2013 15:50:12] NPCD: ThreadCounter 0/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 15:50:12] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 15:50:12] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 15:50:27] NPCD: Found 7 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 15:50:27] NPCD: DEBUG: load 12.570000/10.000000
[02-13-2013 15:50:27] NPCD: WARN: MAX load reached: load 12.570000/10.000000 at i=0[02-13-2013 15:50:42] NPCD: DEBUG: load 11.740000/10.000000
[02-13-2013 15:50:42] NPCD: WARN: MAX load reached: load 11.740000/10.000000 at i=1[02-13-2013 15:50:57] NPCD: DEBUG: load 10.400000/10.000000
[02-13-2013 15:50:57] NPCD: WARN: MAX load reached: load 10.400000/10.000000 at i=1[root@DERNAGIOSXI01 var]#
It looks like you are hitting your NPCD configuration's load threshold please change the values to the following:
In:
Change:
To:
In:
/usr/local/nagios/etc/pnp/npcd.cfgCode: Select all
load_threshold = 10.0Code: Select all
load_threshold = 15.0Re: No Metrics or Performance Graphs
Made change as described.
Below is the Tail from the npcd.log
I am still not seeing any graph data (other than that for _Host_ )
Have verified all monitored services and hosts have process perfdata enabled.
[02-13-2013 16:23:54] NPCD: ThreadCounter 0/5 File is 1360772616.perfdata.host
[02-13-2013 16:23:54] NPCD: Regular File: 1360772616.perfdata.host
[02-13-2013 16:23:54] NPCD: A thread was started on thread_counter = 0
[02-13-2013 16:23:54] NPCD: Processing file 1360772616.perfdata.host with ID -1215628432 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360772616.perfdata.host
[02-13-2013 16:23:54] NPCD: DEBUG: load 4.900000/10.000000
[02-13-2013 16:23:54] NPCD: Processing file '1360772616.perfdata.host'
[02-13-2013 16:23:54] NPCD: ThreadCounter 1/5 File is 1360772631.perfdata.host
[02-13-2013 16:23:54] NPCD: Regular File: 1360772631.perfdata.host
[02-13-2013 16:23:54] NPCD: A thread was started on thread_counter = 1
[02-13-2013 16:23:54] NPCD: ThreadCounter 2/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 16:23:54] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 16:23:54] NPCD: Have to wait: Filecounter = 3 - thread_counter = 2
[02-13-2013 16:23:54] NPCD: Processing file 1360772631.perfdata.host with ID -1227883664 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360772631.perfdata.host
[02-13-2013 16:23:54] NPCD: Processing file '1360772631.perfdata.host'
[02-13-2013 16:23:54] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 16:24:09] NPCD: Found 3 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 16:24:09] NPCD: DEBUG: load 4.730000/10.000000
[02-13-2013 16:24:09] NPCD: ThreadCounter 0/5 File is .
[02-13-2013 16:24:09] NPCD: ThreadCounter 0/5 File is ..
[02-13-2013 16:24:09] NPCD: ThreadCounter 0/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 16:24:09] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 16:24:09] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 16:24:24] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 16:24:24] NPCD: DEBUG: load 4.300000/10.000000
[02-13-2013 16:24:24] NPCD: ThreadCounter 0/5 File is .
[02-13-2013 16:24:24] NPCD: ThreadCounter 0/5 File is ..
[02-13-2013 16:24:24] NPCD: ThreadCounter 0/5 File is 1360772661.perfdata.host
[02-13-2013 16:24:24] NPCD: Regular File: 1360772661.perfdata.host
[02-13-2013 16:24:24] NPCD: A thread was started on thread_counter = 0
[02-13-2013 16:24:24] NPCD: Processing file 1360772661.perfdata.host with ID -1215628432 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360772661.perfdata.host
[02-13-2013 16:24:24] NPCD: Processing file '1360772661.perfdata.host'
[02-13-2013 16:24:24] NPCD: ThreadCounter 1/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 16:24:24] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 16:24:24] NPCD: Have to wait: Filecounter = 2 - thread_counter = 1
[02-13-2013 16:24:25] NPCD: No more files to process... waiting for 15 seconds
[02-13-2013 16:24:40] NPCD: Found 3 files in /usr/local/nagios/var/spool/perfdata/
[02-13-2013 16:24:40] NPCD: DEBUG: load 5.960000/10.000000
[02-13-2013 16:24:40] NPCD: ThreadCounter 0/5 File is .
[02-13-2013 16:24:40] NPCD: ThreadCounter 0/5 File is ..
[02-13-2013 16:24:40] NPCD: ThreadCounter 0/5 File is host-perfdata.1330987694-PID-2109
[02-13-2013 16:24:40] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-13-2013 16:24:40] NPCD: No more files to process... waiting for 15 seconds
Please make sure that you are restarting NPCD after you make these changes.
In addition to adding the load increase, increas the timeout range as well:
In:
Change:
To:
In:
/usr/local/nagios/etc/pnp/process_perfdata.cfgCode: Select all
TIMEOUT = 5Code: Select all
TIMEOUT = 15
service npcd stopCode: Select all
killall -9 npcdCode: Select all
service npcd startRe: No Metrics or Performance Graphs
Thanks for assistnace so far.
Still no joy though.
Please see latest output.
[02-14-2013 10:30:49] NPCD: Processing file '1360837836.perfdata.host'
[02-14-2013 10:30:49] NPCD: No more files to process... waiting for 15 seconds
[02-14-2013 10:31:04] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[02-14-2013 10:31:04] NPCD: DEBUG: load 6.360000/15.000000
[02-14-2013 10:31:04] NPCD: ThreadCounter 0/5 File is .
[02-14-2013 10:31:04] NPCD: ThreadCounter 0/5 File is ..
[02-14-2013 10:31:04] NPCD: ThreadCounter 0/5 File is 1360837851.perfdata.host
[02-14-2013 10:31:04] NPCD: Regular File: 1360837851.perfdata.host
[02-14-2013 10:31:04] NPCD: A thread was started on thread_counter = 0
[02-14-2013 10:31:04] NPCD: ThreadCounter 1/5 File is host-perfdata.1330987694-PID-2109
[02-14-2013 10:31:04] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-14-2013 10:31:04] NPCD: Have to wait: Filecounter = 2 - thread_counter = 1
[02-14-2013 10:31:04] NPCD: Processing file 1360837851.perfdata.host with ID -1217246352 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360837851.perfdata.host
[02-14-2013 10:31:04] NPCD: Processing file '1360837851.perfdata.host'
[02-14-2013 10:31:04] NPCD: No more files to process... waiting for 15 seconds
[02-14-2013 10:31:19] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[02-14-2013 10:31:19] NPCD: DEBUG: load 6.190000/15.000000
[02-14-2013 10:31:19] NPCD: ThreadCounter 0/5 File is .
[02-14-2013 10:31:19] NPCD: ThreadCounter 0/5 File is ..
[02-14-2013 10:31:19] NPCD: ThreadCounter 0/5 File is 1360837866.perfdata.host
[02-14-2013 10:31:19] NPCD: Regular File: 1360837866.perfdata.host
[02-14-2013 10:31:19] NPCD: A thread was started on thread_counter = 0
[02-14-2013 10:31:19] NPCD: Processing file 1360837866.perfdata.host with ID -1217246352 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360837866.perfdata.host
[02-14-2013 10:31:19] NPCD: Processing file '1360837866.perfdata.host'
[02-14-2013 10:31:19] NPCD: ThreadCounter 1/5 File is host-perfdata.1330987694-PID-2109
[02-14-2013 10:31:19] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-14-2013 10:31:19] NPCD: Have to wait: Filecounter = 2 - thread_counter = 1
[02-14-2013 10:31:19] NPCD: No more files to process... waiting for 15 seconds
[02-14-2013 10:31:34] NPCD: Found 4 files in /usr/local/nagios/var/spool/perfdata/
[02-14-2013 10:31:34] NPCD: DEBUG: load 5.110000/15.000000
[02-14-2013 10:31:34] NPCD: ThreadCounter 0/5 File is .
[02-14-2013 10:31:34] NPCD: ThreadCounter 0/5 File is ..
[02-14-2013 10:31:34] NPCD: ThreadCounter 0/5 File is 1360837881.perfdata.host
[02-14-2013 10:31:34] NPCD: Regular File: 1360837881.perfdata.host
[02-14-2013 10:31:34] NPCD: A thread was started on thread_counter = 0
[02-14-2013 10:31:34] NPCD: Processing file 1360837881.perfdata.host with ID -1217246352 - going to exec /usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1360837881.perfdata.host
[02-14-2013 10:31:34] NPCD: Processing file '1360837881.perfdata.host'
[02-14-2013 10:31:34] NPCD: ThreadCounter 1/5 File is host-perfdata.1330987694-PID-2109
[02-14-2013 10:31:34] NPCD: File 'host-perfdata.1330987694-PID-2109' is an already in process PNP file. Leaving it untouched.
[02-14-2013 10:31:34] NPCD: Have to wait: Filecounter = 2 - thread_counter = 1
[02-14-2013 10:31:35] NPCD: No more files to process... waiting for 15 seconds
