[WARN && CRIT] check_disk
Hello everybody,
One simple questions:
With this command:
/check_disk -M -w 20% -c 10% -E -p /
DISK CRITICAL - free space: /dev/sda1 5840 MB (10% inode=86%);| /dev/sda1=48902MB;46137;51904;0;57672
Are you agree with me if I write this for the perf data:
Current use: 48902MB
Warning level: 46137MB
Critical level: 51904MB
Scale 0 to 57672
Why is the disk critical??? The critical is by 51904MB and the current is 48902MB. There should be not a Warning??
Thanks in advance.
Best Regards
With this command:
Scale 0 to 57672
Thanks in advance.
Best Regards
Re: [WARN && CRIT] check_disk
Hi ceeper,
So you have 10% left (critical value).
The 86% is the inode usage.
Run on the server:
To view the inode usage.
Run:
To view the free space (this will correspond to 10%).
Kind Regards,
Gary Shergill
(10% inode=86%)The 86% is the inode usage.
Run on the server:
df -hi /Run:
df -h /Kind Regards,
Gary Shergill
Hi Gary,gshergill wrote:Hi ceeper,
So you have 10% left (critical value).Code: Select all
(10% inode=86%)
Run on the server:To view the inode usage.Code: Select all
df -hi /
Run:To view the free space (this will correspond to 10%).Code: Select all
df -h /
Kind Regards,
Gary Shergill
Thanks for your repply.
Ok I understand, but The performance data say me that the critical is at 51904MB, and the current is 48902MB...
Why my graph show me a Warning?
Best Regards,
C.
It is showing you a warning because your warning value is below where the actual amount of space left is. If it passes the threshold then it will trigger a warning.
Yes the graph say me the truth, I'm over the Warning threshold, I'm agree with this.slansing wrote:It is showing you a warning because your warning value is below where the actual amount of space left is. If it passes the threshold then it will trigger a warning.
But the plugin output give me a CRITICAL.
Why this differencie?
Regards,
C.
Hi creeper,
When you run the command:
Do you get the Use% as 90%?
Kind Regards,
Gary Shergill
Gary Shergill
Hi,gshergill wrote:Hi creeper,
When you run the command thresholdDo you get the Use% as 90%?Code: Select all
df -h /
Kind Regards,
Gary Shergill
Yes exactly, it's possible to adapt warning and critical threshold in the graph (perfs data) to acording with the reallity?
Regards.
Hi creeper,
Sorry, I'm not sure about the graphs, I don't know what data they use, just wanted to confirm that the check_disk is correct on the command line (which it is).
Sorry can't be of more help.
Kind Regards,
Gary Shergill
Kind Regards,
Gary Shergill
How large is the entire disk that you are monitoring? Are you asking how to change the graph so it shows the total size? And not the critical threshold?
I find out the problem, there are 5% of the space used by the root. And this 5% is not calculed by the performance data.slansing wrote:How large is the entire disk that you are monitoring? Are you asking how to change the graph so it shows the total size? And not the critical threshold?
--> https://github.com/nagios-plugins/nagio ... ns/pull/22
Regards,
